Got it all mounted, cleaned and lubed.
I ended up using Greased Lightning, which is a water based degreaser similar to simple green or super clean. I found it works better than Simple Green, maybe not quite as good as Super Clean, but it's not nearly as fumy so I like it better.
The manual is terrible. I thought the manual for my mini mill was bad, this one takes the suck to a whole new level. Does lathemaster offer manuals for the 8x14? I wonder if theirs is any better. I eventually figured out how to switch gears for different feed rates.
Stock tool holder is a joke. Man am I glad I ordered the quick change tool post. I thought the quick change tool post was a luxury, as it turns out it's an absolute necessity. The stock tool holder has no mechanism for centering the tool bit. You have to actually stack shims underneath the tool bit to achieve center.
There was a problem with my threading indicator. The dial was not concentric with it's shaft and it was rubbing badly on the housing. This was causing the gear to slip threads on the lead screw, among other problems. Luckily that was easy to fix, now that I have a lathe.
Chucked it up in the 4-Jaw, centered off the shaft and shaved about 5-10 thou off the OD of the dial, just until there was no more interrupted cut and both shaft and dial were concentric. Works perfectly now.
