OK, here's a weird one...
Part of my hobby here also goes into my volunteering for a performance road rally (can you say "Travis Pastrana" or "Ken Block?"). I am looking for a personal strobe to use at two signs that are posted on the roadside at the end of the stage.
Background info:
This is a motor sport where cars are driven at high speed on closed, "real" roads (usually unpaved) and no guardrails. The signs I need to mark are the warning of the upcoming end of the timed stage and the actual "flying finish" sign where the cars are timed. The teams know where the signs should be but I need to mark the precise location even if the signs are not visible.
The signs have come down in the past although they are on stakes driven in the ground. Not only are we out in the woods but there is a good reason they call it the "flying finish" since the cars go past at very high speed. Cars have hit the signs (the signs are only made of lightweight plastic) and in rough weather they get knocked down.
So here are the requirements and in their priority:
1. Has to be visible in daylight and from a distance. Conditions can be bright & sunny but also in snow, rain, mud, dust, etc. The strobe must be bright and water/weatherproof.
2. A strobe pulse that is too slow won't do the job but in addition the strobes need to function for a few hours. I want reasonable pulse rate and run time.
2. The signs are in a dangerous location. The lights have to be durable and dependable. Standing next to a sign or going to fix a strobe during the running of the stage could be fatal. Reliability really is a life saver.
3. I want strobes to match the sign color, one yellow and the other red. They are set up in that order so using a yellow lens or a filter on the first one won't block as much of the light as for the red one but both need to be colored.
4. I'm broke and cheap. I want to keep the budget for the two strobes, the lenses/filters, and anything I use to attach them to a tree or post has to total only about $100.
I already have some very good ideas however I value the input of this forum and while guesses and "how abouts" are welcome what I really want is some "been there, done that" or "how I use my strobe" info.
Thank you all immensely in advance.
Background info:
