Looking for alternatives to Streamlight Microstream
timbo813
I'm in the market for a new EDC and want to see if there is something that would fit my needs better than a Streamlight Microstream USB.
The Microstream checks a lot of boxes.
  • I love the size and the ease of use. The slim diameter is important to me, which is why I'm not carrying a AA sized light for EDC.
  • A single forward press to momentarily turn on the light and then release to turn off is convenient but not required. A reverse clicky with the right UI would be fine.
  • For much of my use the 50 lumen low mode is sufficient and that gives pretty good battery life out of the smaller light.
  • With the black version it comes on in low and then the high mode is just another click away. This is nice and simple.
  • I've had good luck with the reliability of my Microstream.
  • I have very little issues with the button on the Microstream turning on while clipped to my pocket. Some other small lights have turned on inadvertently.
There are a couple things I don't love about it.
  • I'd like direct access to a moonlight mode without having to cycle through it every time I turn on the light. The programmable zebra lights are nice for this and the Anduril UI is great as well. Both give me the ability to single click for "medium" which I set to 50-100 lumens, long press for moonlight, or double click for high. No other fancy strobes or SOS is needed. I don't care if they are there, just don't make me cycle through them to access something I want.
  • The tint of the Microstream is just OK and the CRI could be better. That said, I'm not a tint snob so this is less important than some of the other things.
  • Microstream reliability has been fairly good but I know there are better quality lights out there.
Budget is a consideration but I'm willing to pay for what I want. A new Microstream is ~$35 which is a pretty decent deal. If something really checked all my boxes I'd pay ~$150ish for that.
So far, I haven't found anything that makes me want to order it instead of another Microstream. Anyone have suggestions for something that fits my needs better? If there was a light with the same size, Anduril UI, and better emitter, I would be all over it. Thanks
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__x__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! 🙂
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
__x__Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
_x___I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
__x__TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__x__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__x__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
__x__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
__x__I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__x__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
__x__I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
__x__I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
__x__I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
__x__I want to navigate a dark room or read a map (1-10 lumens).
__x__I want an indoor "blackout" light (15-50 lumens)
__x__I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
__x__I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__x__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__x__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
__x__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__x__5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
__x__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_x___Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
__x__I want a forward clicky (Helpful for momentary activation and signaling).
__x__I want a reverse clicky (For use with multi-mode/level lights).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
__x__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
__x__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
__x__I don't care.
____I don't know.
15) Water resistance
____None needed
__x__IPX4 (Splash resistant)
__x__IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
__x__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_____________________________________________
____"Hybrid" light (bright incandescent combined with long running LEDs)
__x__Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
Although I'm not too familiar with lights in the same segment w/ the Microstream USB, I did review its specs, and looked around a little for something I think I'd rather have that meets most of the same important requirements. I haven't come up with anything, and the ones that came the closest were in the 2xAA format, which among other things are considerably longer (by almost 2"). I guess at the end of that brief exercise, I just found myself wondering why I don't already have a Microstream USB, because it looks like something I'd like find useful and would like to have myself. I guess I'm not much help, but I'll keep an eye out for something;-)
You're likely better off just buying another Streamlight Microstream.
You found something that works well for you.
