I have both Photon ReX and HDS U60 (similar to Novatac). Both are very dim and will fully preserve night vision.
The ReX is a little dimmer, but my HDS is modified with an SSC P4 emitter, so is a bit brighter on the lowest level than stock. The ReX can start at the lowest level and ramp up -- you just press and hold. The ReX also has a glow-in-the-dark button to make it easier to find.
I think a stock HDS or Novatac at 0.08 lumens is probably about equal to the ReX, but I don't have one to measure.
Another option (ironically) is a Fenix P3D Q5 with AW rechargeable cells and a red filter. Using rechargeable cells the low level is dimmer than normal, and the red filter dims it further plus shifts color to preserve night vision. Lighthound has the cells and filters:
P3D Q5:
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=3220
Filter:
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=2960
AW RCR123A:
http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=1155&HS=1
The HDS (and I assume Novatac) run time on the lowest level is extremely long. I'm doing a run time test on my HDS at the lowest level. So far it has been constantly on -- non-stop -- for a month at level 20.
The ReX is rechargeable, so that's a nice feature.
