Geogecko
A friend is asking for some assistance from me to find an infrared LED for a project he is working on. The problem is finding an LED that operates at 1070nm, which is what the wavelength needs to be for the given project. Most common IR LEDs out there are around 870nm.
Has anyone seen any around this wavelength, and also at a fairly high power (around 100mA, or 150mW) output? If so, where, and who makes them?
Edit:
I've gotten some clarification on this, and really, the LED needs to be high power, such as 6W. There are some out there, but they run about $400 each, and for this project, about 150W of power are needed, which means about 25 of these, which as you can see, would be a large amount of money.
If there would be some at maybe 1W that would be a lot cheaper, such as the Luxeon LEDs or similar, that would require 150 of them, but that would be better than using 1,000 of the 150mW LEDs, which may be impossible anyway, since the available space is not that large.
Thank you!
Edit:
Thank you!
