Not true. I supplied the industry standard optimal storage targets, typically 35-50% SOC (depending on storage time, ambient temperature).
Be aware that a lot of info in the RC/hobby world is outdated, e.g. many RC chargers use cloned firmware that still has the ancient distinction between Li-ion(3.6/4.1) vs LiPo(3.7/4.2).
Even for higher voltages chemistries typically used in RC packs (where 3.85V is about 55% S0C), this is not the storage SOC that is optimal for prolonging life. Rather, optimal storage SOC is typically between 35-50% SOC (about 3.77-3.82V). For example, if you look at the datasheet for Sanyo/Panasonic NCR18650BE you will see that they are shipped at 35% SOC, i.e. slightly over one-third capacity.
Yes it is true you just did it again. Ncr18650b batteries are not what he was asking about. What your saying is that EVERY SINGLE lipo manufacturer including the highest quality and most respected companies are all wrong and your right. simply because you saw a data sheet for 18650 batteries which is not even what we're discussing.
Do some searching for info on lipo batteries NOT 18650 and you will see they recommend 3.85v for storage. This comes from the battery manufacturer.
A quick Google search for lipo battery care and this is from the first link: For the longest life of the batteries, LiPos should be stored at room temperature at 3.8V per cell.
Scroll down to the 3rd result and you get this
Maxamps website says: Storage Procedure: When not using your LiPo/Life battery pack, store it at 60-70% of the pack’s rated capacity.
There are many more if you care to look.
