looking for ROP bulbs
lctorana
Melbourne, Australia
Being D size, and high-capacity, the bulb could be seeing as much as eight volts on initial power-on.
I recommend either:
a) switching to the 3853H, or using a 1274 in a bi-pin socket. These will give similar output.
b) sticking with the 3854H, but wiring a NTC into the circuit somewhere. Or even going with a soft-start regulator, but that's a comparatively expensive option.
seatrue
Hey, THANKS for the advice. choices, choices. -i guess i was a little hung up on my lipstick red 6D Mag with a KD 8.3mm opening MOP reflector and pointy little 3854H bulb. -that was pretty BA :devil:. just downgraded that one to the 3854L for now until i pick up the 3853H. sounds like it will work.
fortunately, i picked up a second 6D Mag waiting on a KD SMO reflector which i want to keep in pristine condition and use with the 3854H strictly as a show off light (throw, etc.) think i'll try my luck with a couple more of those bulbs (any requests to swap a few 3854L with 3854H??). the very first 3854H bulb i had seemed to work fine. had it on for well over half an hour once and ran it fresh off the charger at least a few times. maybe a future upgrade to the flashlight is in check. hopefully it'll work again...
seatrue
to add a note: i just walked into Radio Shack, and they were selling off their discontinued nicads for $2 a pack. (pretty darn cheap - couldn't pass that one up) anyways, i ended up with 8 C 2000mah cells. put 7 of them (along with the aid of a PVC pipe) into my 6D mag with 3854 low bulb and it handled it great right off the charger @ 9.4 volts (after 20 minutes of use the voltage was still at 9.0). very bright - i think around 900 - 1000 bulb lumens!
i even tried 8 cells @ 10.7 volts. i kind of new this would fry the bulb - didn't think that it would actually light up for a second like it was attempting to handle all 8 cells! -surely a tough little 6 volt bulb!!
:popcorn:
Minimoog
Bumping an old thread, but are these still available? I am looking for them online but no luck - perhaps being in the UK is filtering out the places that sell them? Thanks for any help - I have a Mag that would really appreciate the 3854-L.
Greenbean
WNC
Last set I ever saw new in package was on eBay a few weeks ago. They were 3804 Big D bulbs for 6 D cell Pelican lights. Guess they were old stock or something.
I am not sure what the lumen specs are on the 3804, but the packaging says for 6 D lights.
fivemega
California
Pelican 3853 and 3854 have been discontinued long time ago.
Currently, I have some custom bulbs with spec close to what you need. PM me if interested.
3804 is designed to work with alkalines and current draw is too little than 3853-L
saeckereier
Strange to think that some day soon these will be pretty much impossible to come by.
I'll hold on to the two packages I have for my C maglite ;)
Greenbean
WNC
I have a new Mag 6D that hopefully will get some nickel metal hydride cells.
I know it's going to be a big heavy light, but it kind of sits on the shoulder easily, I still have to research from years ago which bulb is going to be the best to use in that, I think it's the 3853 HO.
I like the idea of almost 10,000mAh also.
novice
LuxLuthor's incredibly useful data didn't include any service life for the 3853/3854 bulbs. Does anyone have any expected lifetimes (especially at 7.4 volts)?
