Looking for small metal reflector for HID bulb
Flashanator
The 11th Dimension
Need some help in finding a small (~6-7cm in diameter) metal reflector for a asian type H3 HID bulb.
Any suggestions? I don't know where to start looking.
thanks.
What about FM's 2.5 and 3" reflectors? You'll probably have to drill out the base to open up the hole.
Hmm, not shore how I would mount the bulb in those? Are they just the reflector or head housing too?
I need it to throw a wide beam about up to ~200meters.
Probably asking too much.
FM would sell you whichever pieces you needed if you think it you can make it work. Nothing is going to be "drop-in" for this type of application. I mean to say that if you are thinking about locking it in with a spring clip like on a Thor reflector....it's not going to be ready to go or anything. The smaller HID's and reflectors have bulb ballast combos not H3 retainers. I just thought that you were working on a custom project and assumed anything you'd be doing would require special work.
You could also look at AE reflectors since they're about in the same size range.
