OK well I`ve been distracted by all the pretty fireworks outside for most of this evening (for`tis Bonfire Night here in the UK) but they`re all but gone now so I`ve now had chance to make some interesting colours myself here inside.
First, the raw materials- Red, Green and Blue Luxeon Star LEDs. The current "batwing" types. For the sake of fairness, and the fact that my main PSU`s all messed up so the current limit doesn`t work right any more, they`re running at 254mA each, connected in series to what`s left of the constant current output.
Also my tripod broke and now it won`t reach up to my main target till I find that pesky roll of Duck tape and fix it, so I`m using my clone of Craig`s target that lives below it. I`ve got
just enough component catalogues to prop up that broken leg to the right height, and....
<center>
</center>
Taken at slightly different iris settings, so as to show the colour as best I can. No time for color correction as it`s quite late, sorry. But they`re close enough.
Combinations? Well, first thing you`ll note is that the blue overwhelms the others. This is mostly true, the blue LS is the broghtest, followed by Red, then green pulling up the rear. That and the fact that my old VC is most sensitive to blue light (can`t even see IR) and as such, blue flares out brighter than it should.
Here- Red and Blue....
<center>
</center>
Red and Green...
<center>
</center>
Blue and Green...
<center>
</center>
All 3....
<center>
</center>
Unfortunately the beams do not overlap too well- each is a slightly different shape. They were all held about 17ins from the target and aligned the best I could. The "white" colour produced by all 3 is less blue than this, more a pinky/violet colour overall, due to the green`s deficiency.
I reckon that Lambertian (the new ones) LEDs, in their naked form, would blend rather more nicely- no rings or hotspots to spoil things, but a wide flood beam instead of a spot. Either that, or a diffusing of these focussed beams (through a material like CK uses in their Sauce LightWasher- to diffuse the light from the 5mm LEDs inside).
Anyway I hope this has helped, and sorry for the poor colour rendering. Assume less emphasis to the blue in reality, though it is still quite potent and ideally needs toning down. Perhaps 250mA through red and blue and 350mA through green? Something I may try in the future when there`s more time.
