LS heat and heatsinks
ReconTech
Atlanta, GA
At what voltage does a Star/O with optics need a heatsink? What voltage does the Reactor2 run at? Is it 3 volts considering it is not regulated.
Just how much heat does a 1 watt LS put out at full voltage, what are some heatsink suggestions?
My LS/O gives a good amount of light and not much heat at 3.0 volts.
Try bolting it to a piece of aluminum flat bar with a piece of heat sink pad in between. You can keep cutting back on the flat bar until you get to a limit.
