logicnerd411
The bottom contact of the LS is negative or positive?
<font size="2" face="Verdana, Arial">The LS LED. Anyone sure?Originally posted by darell:
Of the Arc LS or a Luxeon Star LED?
<font size="2" face="Verdana, Arial">Quote is from this pdf: DS25.pdfThe anode side of the device is denoted by a hole in the lead frame.
Electrical insulation between the case and the board is required-slug of device is not electrically neutral. Do not electrically connect either the cathode or anode to the slug.
<font size="2" face="Verdana, Arial">See this thread:Originally posted by logicnerd411:
<font size="2" face="Verdana, Arial">No.Originally posted by logicnerd411:
I'm still confused. Here's the situation:
I ordered a bare LS from Wayne Y. at the CPF Shop. I am trying to put it into a small tube that holds a 123A. Can the battery nipple (positive) touch the BOTTOM of the LS?
<font size="2" face="Verdana, Arial">OH!!!!!!!!Originally posted by darell:
Now I see what the question is. The little wings that stick out the sides are the contacts. The bottom metal plate is for heat-sinking. This NEEDS to be sinked. The positive wing is the one with the complete "o" next to it in metal. The negative wing is the other one. Don't use the bottom plate as the positive contact.
