OK, so I want to put a light on my bike, it will have 3 White Seoul P4-U in the front and one Red Seoul P4-U in the rear. Same thing for the helmet. So, 6 LEDs total forward and 3 red ones in the back.
With that I should be able to see stuff, lol. Also I have noticed that my test-rig with only 1 Seoul P4 on the handlebars earns respect from drivers, so it will make for safer cycling.
So, battery voltage is more or less fixed between 10V and 15V because of the car horn (bough at scrap yard, much better than airzound, totally deafening, perfect).
Problem is, LED voltage is in the same range as battery voltage so I need a buck-boost regulator. Also, efficiency of drivers found on the web isn't that high, so out comes LTC3780.
The design is slightly complex because this circuit uses synchronous rectification and also the current regulation. So, I will use a ZXCT1051 current probe with a 0.1 Ohm current resistor. Hunting for the right MOSFETs was quite difficult, but DigiKey revealed the FDS8878 which looks good.
Due to the number of parts, this should be a bit expensive (especially the LTC3780) but the most expensive part is as always the PCB.
Features :
- Input voltage : 6V-20V
- Output voltage : 6V-20V
- Output voltage above, below or equal to input voltage
(actually the parts are 30V-rated)
- Output current : settable between 0 and 1A with potentiometer (actually, it would probably deliver up to 30W or something)
- Also configurable as a voltage regulator for powering the GPS etc
- Efficiency : 95% according to LTSpice
- Open circuit protection, short circuit protection, etc
- Hi/Lo beam : press a button and it goes to full power, release and it goes back to normal.
- Size : 40mm x 40mm
I am finishing the schematic and will post it shortly.
So, if anyone has tried this circuit before, do you have special advice ?
Thanks for any info
Features :
Thanks for any info
