Lumahunter MRV question
machoamigo
Hi Guys,
I have the Lumahunter MRV which I had purchased from qualityflashlights.at and it came installed with the GID tailcap, but I am not sure whether the tactical tailswitch is installed or the normal clicky installed because when I turn the tailswitch end anticlockwise the light does not come on when the button is pressed somewhat like the Surefire lights. Can anyone here help?
Thanks in advance.
When you look into the tailcap
the tactical/momentary switch is brassy colored
the two-stage switch is bare aluminum colored
So... the MRV is supposed to have a high and low, with the bare aluminum switch? Mine only does high, could it be defective?
By the way, I am extremely impressed with the quality of this light.
Woops, OK, I figured it out. Twist the body from the silver ring, and it is slightly dimmer. Would be more useful with a difference similar to the D-Mini two stage. Still a fantastic light.
