Will the AW batteries charge on the UltraFire charger I just bought?
Alan, lithium-ion AAA batteries require a lower charging rate than other battery types (150 mAh I believe*). Most chargers not dedicated for AAA lithium-ion cells have a charge rate of 250 mAh or higher, and since these are
unprotected cells, I felt it was smart to just get the best cells/charger combo available....... and that would be this (IMHO):
http://www.cpfmarketplace.com/mp/showthread.php?t=79847
Of course the main thing when using these
unprotected cells is to not let the voltage go below 3.0 volts, as that can (not always) render them unusable. Some lights have a flashing warning for low voltage, however the Avenger does not, but from my testing I found that if you stop using the battery just when the light begins dimming then the voltage should still be above 3.0 volts.
The way I deal with this is to just change cells every so often before they even get low (one a week usually) and then top off the used one. Heck, if you recharged each cell once a week, that would still give you over 5 years of service.
Just in case you haven't seen this:
http://www.batteryuniversity.com/
An excellent resource for all things battery related.
Edit: *After reviewing the information on AW's battery page, I can see that the WF-138 charger, which has a 250 mAh charging rate, can be used to charge AAA lithium-ion batteries. Sorry for any confusion on my part.
