chevrofreak
adirondackdestroyer asked me if I would like to do some runtime tests on his D-Mini to confirm the other reports that it is infact not regulated. Having not yet seen a D-Mini I took him up on the offer.
Total output numbers taken at the beginning of the run using my home built integrating sphere.
Lumapower D-Mini - AW high current 750mAh RCR123: 1671 (est 119.36 lumens)
Lumapower D-Mini - Energizer E2 CR123a: 1477 (est 105.5 lumens)
Here it is compared to the Fenix P1D CE on high.
I am actually fairly impressed with this light. The beam isn't as ringy as I was expecting from a smooth reflector, and it has insane throw. A pocket sized spotlight indeed! It's big for being only a 1x123 light, but it fills my hand very well and feels very solid. It's just too bad it isn't actually regulated, but the performance on AW's new high current 750mAh RCR123's is quite good.
Something to note, just before the circuit in the cell shut down the light started flickering fairly rapidly. If that happened reliably it would be a good warning that you were about to lose light.
