ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just got the ES (Engineering Sample) from Lumapower courtesy of Ricky Tsang.
Lumapower's D-Mini link to the 18650 Battery Tube. http://www.cpfmarketplace.com/mp/showthread.php?t=167899
The battery tube converts the CR123 size to a 18650 size.
The first step is unscrew the Lens Assembly from the Bezel.
I used a pick to unscrew the Cree Module from the Bezel.
Turn counterclockwise.
This is what the Cree Module looks like.
Once the Cree Module is out you need to take the CR123 Battery Tube off the Lens Bezel Assembly.
I removed the o-rings from the Bezel end the Tailcap.
I had to boil the D-Mini's Bezel Assembly twice, once at 10 minutes and again at 10 minutes to finally break the glue.
I tried using a plier with a rag on the "teeth" part. I broke the glue a little but not much. I decided to use my Workmate Bench because I put some dings and scratches in my CR123 Battery Tube.
I put the D-Mini's Bezel Assembly in my Workmate Bench
I had to use a Strap Wrench
It was tough but I finally got the Bezel off the CR123 Battery Tube.
This spacer needs to be installed first in the new 18650 Battery Tube. The smaller end faces down. The smaller end makes contact with the 18650 Battery. The Larger end on top makes contact with the Cree Module.
This end should face up. It has 2 holes, Remember the larger end of the spring faces up towards the Cree Module.
Screw in the Cree Module clockwise.
I found out I had to find the "sweet spot" to make contact to the module. If your Cree Module doesn't light you have to adjust the module to make contact.
Screw in the Cree Module.
The Cree Module has to be flush with the 18650 Battery Tube end.
Before screwing the D-Mini's Lens Bezel Assembly on turn on the light to see if it works. If not you have to find the "sweet spot" of the spacer to make contact with the Cree Module.
Now it's time to have some fun!
Size difference between both tubes. Top, 18650 Battery Tube. Bottom CR123 Battery Tube.
The 18650 Battery Tube has ample room for AW's Protected 18650 Battery.
Beam shots of the CR123 and 18650 Battery Tubes installed.
D-Mini with CR123 Battery Tube @ 79"
D-Mini with 18650 Battery Tube @ 79"
D-Mini with CR123 Battery Tube @ 79" Stepped down exposure.
D-Mini with 18650 Battery Tube @ 79" Stepped down exposure.
I used the D-Mini's SMO Reflector to make sure I had the Cree Module installed correctly.
If installed correctly the beam from the CR123 Battery Tube and the 18650 Battery should be identical.
Both beam shots with the different Battery Tubes used freshly charged Batteries.
