Lumapower M1 Cree XR-E - Mini Review - UPDATE: vs M3, M1 SSC P4, T5
lexina
Re: Lumapower M1 Cree XR-E - Mini Review (lots of pictures)!
great review! thanks!
atm
Australia
Many thanks whc, great stuff!
whc
Copenhagen, Denmark
Just got my LP-Mini today, and thought it would be fun to take some wall shots, here they are, enjoy :).
Also got me a second M1, now I have one for the smooth and op-type reflector, much easier than to change the reflector :D. And that also means that i can post wall comparison between the smooth and op-type reflector side by side, enjoy :).
Left: Lumapower M1 XR-E, Right: Lumapower LP-Mini (both with OP-Type reflector)
Left: Lumapower M1 XR-E, Right: Lumapower LP-Mini (both with OP-Type reflector), 2-Steps underexposed
Left: Lumapower M1 XR-E, Right: Lumapower LP-Mini (both with Smooth-Type reflector)
Left: Lumapower M1 XR-E, Right: Lumapower LP-Mini (both with Smooth-Type reflector), 2-Steps underexposed
Left: Lumapower M1 XR-E, Right: Lumapower M1 Luxeon III (both with Smooth-Type reflector)
Left: Lumapower M1 XR-E, Right: Lumapower M1 Luxeon III (both with Smooth-Type reflector), 2-Steps underexposed
Left: Lumapower M1 XR-E Smooth-Type Reflector, Right: Lumapower M1 XR-E OP-Type Reflector
Left: Lumapower M1 XR-E Smooth-Type Reflector, Right: Lumapower M1 XR-E OP-Type Reflector, 2-Steps underexposed
Size comparison (Left to right, L1T, V2, LP-Mini, M1)
bray
Columbia, Sc
Re: Lumapower M1 Cree XR-E - Mini Review - UPDATE: vs LP-Mini and more!
is it me or does the op reflector look almost the same as the smooth beamwise?
whc
Copenhagen, Denmark
With OP-Reflector, the hotspot is more smooth, the dark ring is less noticeable, I personally like the OP-Reflector best. You though loos some throw with the OP-Reflector.
SEMIJim
S.E. Michigan
Once again: It appears to me, from the beam-shots, that the D-Mini is brighter, probably has better throw, and definitely has less artifacts than the M1. I'm not the only one who has noticed this.
I think I prefer the D-Mini's beam patterns, but would prefer the M1's run-time (in its current, pre-1000mA incarnation).
I think I'm going to hold off for a while, after all.
Thanks for the review info, whc!
FASTCAR
Banned
NJ /Oh / Fla
The D-mini is more throw and overall then the M1...how?
whc
Copenhagen, Denmark
The D-Mini throws like no other, but I have not compared it to M1 other than some wall shots. In real life the M1 should out throws the D-mini, since the emitter in M1 gets 750mah, compared to the 550mah in the D-Mini.
It is hard to compare throw wall shots, the LP-Mini I compare my M1 to, does also have another tint that the M1 (M1 I very white, and the LP-Mini is slight purple).
They are both throw monsters, but I would defiantly go for the M1 doe to the longer runtime on 18650, and the throw is more than enough for me. The LP-Mini has bean my EDC ever since I got it, like the momentary on, and the OP-Type reflector, that almost completely eliminates the dark ring, that the XR-E produces. I am impressed every time I turn either of them on, the output power is just awesome...
liquidsix
So there's two clickies to choose from. What kind of output does the single stage clickie do? is it the same as the two-stage high, or the low? Or is it a nice happy medium?
whc
Copenhagen, Denmark
The 1-stage clicky is High only. I think you have to order the 2-stage clicky for $7 extra, it is as far as I know not included as standard, only the ones pre-ordered got one for free duo to delay in delivery of the M1 XR-E :).
HiltiHome
Germany
Here are some pic' for you, showing the LED modul in expoled view:
This pic ist showing the rim measuring 2,65mm, which is by 0,65mm to thick and prevents the bezel screwing down fully
whc
Copenhagen, Denmark
Here are some more beam shots, enjoy :)...
Left: Lumapower M1 XR-E OP, Right: Lumapower M1 SSC P4 OP (both 1x18650)
Left: Lumapower M1 XR-E OP, Right: Lumapower M1 SSC P4 OP (both 1x18650), 2-Stops Underexposed
Left: Lumapower M1, Right: Lumapower M3
Left: Lumapower M1, Right: Lumapower M3, 2-Stops underexposed
Left: T5, Right: M1 XR-E OP Reflector
Left: T5, Right: M1 XR-E OP Reflector, 2-Stops Underexposed
whc
Copenhagen, Denmark
Here is some more beam shots on distance about 12-14m, all flashlights is on high, using Li-Ion rechargeable batteries.
Fenix L1D-CE
Lumapower M3
Amilite T5
Lumapower LP-Mini OP
whc
Copenhagen, Denmark
Lumenation said:
So is the T5 brighter than the M1 SSC? What do you think about the SSC module. Do you prefer the M1 XRE, or the M1 SSC?
The T5 seams a bit brighter (see pic below), though it has a slight blue tint, so it is hard to say without a luxmeter.
I like the SSC module very much, it gives a nice floody beam, depending on task, for indoor or close-up i prefer the SSC, but for distance the XR-E is preferred.
Left: Lumapower M1 SSC P4, Right: Amilite T5
Left: Lumapower M1 SSC P4, Right: Amilite T5, 2-Stops underexposed
whc
Copenhagen, Denmark
I have updated the list, now woth throw and more modes, enjoy :D...
Here is some Lux reading of Overall Output:
Amilite T5:
1xRCR123A 3.0v on high: 8340 Lux
1xRCR123A 3.7v on high: 10910 Lux
Fenix L1D-CE:
1xAA Ni-Mh on turbo: 3990 Lux
1xAA Ni-Mh on high: 3770 Lux
1xAA Ni-Mh on medium: 1910 Lux
1xAA Ni-Mh on low: 430 Lux
1x14500 Li-ion on turbo: 8240 Lux
Led-Lenser Hokus Fokus:
3xAAA Ni-Mh: 4850 Lux
Lumapower M1:
1x18650 XR-E OP on high: 8140 Lux
1x18650 XR-E OP on low: 1640 Lux
2xRCR123A 3.7v XR-E OP: 8950 Lux
1x18650 SSC P4 OP: 5540 Lux
2xRCR123A 3.7v SSC P4 OP: 8230 Lux
Lumapower LP-Mini:
1xRCR123A 3.7v OP: 7810 Lux
Lumapower M3:
1xAA Ni-Mh on high: 3640 Lux
1xAA Ni-Mh on medium: 1270 Lux
1xAA Ni-Mh on low: 40 Lux
2xAA Ni-Mh on high: 4300 Lux
2xAA Ni-Mh on medium: 1310 Lux
2xAA Ni-Mh on low: 350 Lux
1x14500 Li-Ion on high: 5880 Lux
1x14500 Li-Ion on medium: 3020 Lux
1x14500 Li-Ion on low: 690 Lux
1xRCR123A 3.7v on high: 4390 Lux
1xRCR123A 3.7v on medium: 2940 Lux
1xRCR123A 3.7v on low: 680 Lux
Nuwai X-3:
2xAA Ni-Mh: 3020 Lux
Ultrafire WF-500L:
2x18650 3.7v: 4660 Lux
Here is some Lux reading at 1m in Throw:
Amilite T5:
1xRCR123A 3.0v on high: 2520 Lux
1xRCR123A 3.7v on high: 3260 Lux
Fenix L1D CE:
1xAA Ni-Mh on turbo: 1460 Lux
1x14500 Li-ion on turbo: 3150 Lux
3xAAA Ni-Mh: 4460 Lux
Lumapower M1:
1x18650 XR-E OP on high: 4820 Lux
2xRCR123A 3.7v XR-E OP: 5500 Lux
Lumapower M3:
1xAA Ni-Mh on high: 1240 Lux
2xAA Ni-Mh on high: 1530 Lux
1x14500 Li-Ion on high: 1980 Lux
1xRCR123A 3.7v on high: 1550 Lux
Lumapower Lp-Mini:
1xRCR123A 3.7v OP: 4700 Lux
Nuwai X-3:
2xAA Ni-Mh: 1340 Lux
Ultrafire WF-500L:
2x18650 3.7v: 4710 Lux
