Lumapower MVP Review - 3X Cree - BEAMSHOTS, RUNTIMES, COMPARISONS, and more!
EngrPaul
PA
I was using mine to spot 6 deer across the field. :devil: Next time I take my camera/tripod with me. :whistle:
I only have one complaint about this light. To change the batteries properly (at the tailcap, not removing the lanyard ring), you have to TURN and TURN and TURN. Good thing the batteries last so long :thumbsup:
EngrPaul
PA
This light doesn't seem to have any competition, except maybe it's own brother P7. Good job, LumaPower!
EngrPaul
PA
Just a side note, the MVP will not take a flat-topped R18650. The cell must have a small (+) nipple to interface with the (+) electrode on the MVP head.
For instance, a Trustfire unprotected cell will not make contact. No light!
selfbuilt
Good point Paul. However, all my older flatp-top AW protected 18650's would make contact with the head - but I needed to use a magnet to connect the second battery to the first. Not recommended for actual usage (magnets can slip and short!) - stick with button top cells.
HKJ
Copenhagen, Denmark
Just get a small magnet and put on the + pole of the battery, your can get the magnet from DX for nearly no money (less than $3 for 20).
MattK
Connecticut Shoreline
Eric - did you get the new lights yet?
BTW folks, I never recommend the magnet on battery solution as I'm always concerned it could slip and cause a direct short. Now if you Krazy glue the magnet in place then I'd be just fine with that.
EngrPaul
PA
Thanks for the magnet idea, friends. It worked!
The inside of the tube appears to be anodized well, so the chance for a short is small, I would think
HKJ
Copenhagen, Denmark
If the magnet slips, the coating on the inside of the battery tube has a hole and the protection in the battery fails, your get an explosion!:poof:
EngrPaul
PA
My solution: a donut of foam tape (sticky on the battery side) around a smaller magnet: ends up being about as tall as a protected 18650. I tested, it works great in the MVP and the charger. :twothumbs
Left: Protected cell. Center: Final assembly. Right: Parts used.
selfbuilt
Interesting solution Paul. Certainly a lot better than bare magnets, which I think are just too dangerous for regular use on their own.
Tracking shows them arrived in Canada, awaiting customs clearance. :)
jirik_cz
europe
Do you know what will happen when you forget that MVP can't take 4xRCR123 batteries and you will use them? Yeah, the driver will fry :poof::ohgeez::banghead:
Well at least it opportunity to make real MVP Turboforce with 3xMC-E :naughty::D Custom heatsink is already in production...
