Kiessling
Moderator,
Re: Lumen output of Aleph\'s
LEDagent ... IIRC the lumen ratings used by SF are highly conservative and best viewed as "minimum" numbers, your average L4 should be brighter than 65lm. IIRC Gransee has tested one to about 80lm, but I might be wrong.
The L4 is different from the Alephs though as the Aleph1 and 3 head have much superior throw.
Obviously for a maximunm luminous output you'd need a maxed out drive current ... but remember that efficiency and runtime go down strongly then and heat will be an issue depending on your desired combo.
If a DB917 was tested at 65lm in an Aleph, you'd need a DB1200 to notice any difference ...
bernie
P.S.: wasn't this thread about babes?
bernie
