From what I have read. When low is in use the factory 5mm leds still light along with the main led. When in low mode there is current still running to the bulb but beings its an incan its not enough voltage to light up the wire. It is however enough to light and LED so the 5mm come on along with the main LED. Specs read 40 lumens with all leds lit up. 350 on high as you let the voltage flow through.I like the idea of any dual-spectrum gas pedal light with the reliability of an LED that can be powered by a 16650. So, it does have something that piques my curiosity. But, it seems a bit underwhelming at 300 lumens. I'd have to see the beam. I'm not a lumen chaser by any means, but I'd be more interested at 500. Something to give it a clear and overwhelming advantage in some aspect vs. the incan beam. The other thing is, it has a low level. Which seems odd because the A2s already have an LED ring for low mode. With this drop in, do we scrap the ring? Is the A2 just a host for this drop in and we lose the low mode of red, green, yellow-green, etc.?
Here's the specs.350 on high?! I didn't know that!
I'd be much more interested if it still only used the 5 mm leds on low mode.
Well....to start, thanks for the reply. Yes, if one was using colored leds like red. This dropin would make useless. For those that have the crappy factory white leds then its more useful. Sounds like this dropin takes away the great Hotspot that the incan provides due to the shallow reflector, same as leds in the incan e2s etc. Output differences on high may only be 100 lumens or around. Sounds to me the only improvement is runtime, and not by much. I'm not going to waste the 60 bucks on it for sure.@teak
Yes I have one of these. It's my de-facto bulb setup on my only A2. If you'd still want to retain the 5mm low mode and brighter hotspot then this module may not be for you.
So yes the low mode is pretty much defeated with this module. But with white 5mm LEDs then the low mode complements those very well. If however you need low mode in other colored LEDs (red, green etc.) then you're out of luck.
Meanwhile 350lm gross output is not very impressive. I'd say, barely OK for this A2 setup. But the challenge with producing this module is to have its driver work in conjunction with the A2 body's other driver, which steps down everything. So even if LF module is configured to drive harder the in-body driver will offset the extra output.
Forgot the exact specs of the module's driver. Think the drive current is around 1.3-1.4A.
Yes, I'm really surprised more people didn't pick them up. I may still at some point just to try out but I'm in no rush.I read about how Mark had built a really good attempt at an update to the A2 but figured it would probably be about as popular as new Coke was.
The A2 in it's original platform was an either love it or hate it light with both camps deeply entrenched in their reason(s) why. If anything could unite some it was the Lumens Factory LED drop in. lol.
I haven't tried it. Something about putting an LED main beam in an A2 is like putting ice cubes in beer. Just ruins what makes the A2 so great, in my opinion.
