lumens factory help
jbosman1013
michigan
I aquired a older SF 6P from my dad about a month ago, I realized that it was made with much thicker aluminum and thought it would be a great base to make a high power incan from. I purchased a SR-9 and HO-9 in hopes of something truly amazing but I am less than amazed. The SR-9 seems just slightly brighter than the SF P60 (both having identical beam shapes) and the HO-9 is not even as bright as my P61 it just has more throw. I thought the HO-9 put out something like 250 OTF lumens are my eyes deceiving me or is the P61 that much brighter than spec?
we definitely need to know what cells you are running in order to understand what you are dealing with:
However:
Assuming you are driving the lamps correctly, I can still explain your experience scientifically.
first off. Surefire de-rates their lumens so much, that comparison to other brands is difficult. They state a lumen that you can expect on partially depleted cells.
The P60 is a ~4.8V 1.2A bulb. or about 6W. A SR-9 on RCR123s runs about 7.8V fresh off the charger at about 1.22A, making it about a 9W bulb.
The P61 is about a 4.5V 2.5A bulb, or about an 11.25W bulb. The HO-9 runs about 7.4V fresh off the charger at about 1.55A, which makes it a 11.5W bulb.
It takes 30% difference to notice a difference when dealing with lumens because your eyes are always adjusting for the lighting situation, it takes LARGE Logarithmic increases in output to seem substantial. The difference in Lumens between a P60 and SR-9 in reality is only about 30-50% depending on which cells are involved, resistance, etc, just enough to notice a difference and say, "yea, it's brighter" but not anywhere near enough to blow you away.
The P61 and HO-9 are so close in output that it would be nearly impossible to distinguish a difference with the naked eye anyways. They are within ~20% of each-other output wise when you drive the HO-9 on RCR123s (I assume you are?!?!?) which is not enough to REALLY see, especially when you have a difference in beam shape.
to go furhter into this:
If you know what a P61 is like, and you want to be "blown away" you need to move up to a light that is at least 5-10X as bright IMO. That means M6 HOLA or Mag85 territory, If you wanted to be blown away again, you would need to move up again 5-10X, so somewhere around 75W HID, if you want to be blown away again, you need to again, move up 5-10X, that means a 2400W array of landing lights mounted in a large custom suitcase.
please no worries I use AW's, I do like how these lamps throw compared to the surefire I guess I was just expecting more because it is a 9v bulb. I sometimes set my hopes to high and it takes me a bit to realize how bright it really is. For a true high output incan I was thinking of putting something together based off a leaf 2x18650 body any suggestions?
P.S. thanks mdocod, I was hoping I would get some of your wisdom in my thread
An old favourite with some here is the 2x 18650 Leef body and a SF P91 lamp or perhaps if you want a LF lamp then the EO-9 is also good......
For what it's worth, the LF EO-13 700lm LA truly blows me away in comparison to the stock 300lm WE LA and in comparison to the 215 lm P3D Q5 I use. It is very noticably brighter than them to me. Someday (when my newborn twins and 18 MO decide to sleep :laughing:) I will do some beamshots.
Is it possible that the OP got a dud? I don't know if that happens.
Regards,
Taboot
