Lumileds 120lm@350mA Neutral White 1mm2
HumanLumen
Reading, Berkshire UK
As per the title - Lumileds have launched part LXML-PWN1-0120 which is a Neutral White 1mm2 120Lm at 350mA device - so new king of the block for neutral white. Looks like they are slowly catching up with thier press announcment of 132lm at 350mA that they made back in 2007. I await an announcement from Cree, who usually seem to have news stashed away for occasions such as these!
HL
lumileds rebel neutral white, LXML-PWN1-0120: 120lm @ 350mA, 3500-4500K CCT
cree xp-g neutral white, r3: 130lm @ 350mA, 3700-5000K CCT. :thinking:
XP-G has a better maximum drive current of 1.5A vs 1A
XP-G has a better thermal path with 6°C/W of resistance vs 10°C/W
Rebel has a more narrow viewing angle with 120° vs 125°
Both have Vfs of 3.20V @ 700mA according to datasheets :thinking:
Same max junction temperatures of 150°C
Package shapes? either could be good depending on application.
edit:
sure the rebel has a 1mm^2 die?
old:
new according to the site:
There is no definitive size given in the datasheet ds64. However, taking into account the illustration which shows a matrix of 4 x 4 'dots' copared with 5 x 5 for the larger (1.4mm x 1.4mm) Rebel ES, and the fact that the larger ES is 6 deg C/w and the new one is 10 deg C/w, it would seem to indicate that this is not the larger die size. All this is anecdotal evidence of course, but it appears that this is a genuine step forward and in comparison to the similar XP-E (assumed to be aprox similar die size), it is a brighter part in the neutral white.
Any further data chaps?
HL
hrm..
good point @ the rebel ES!
regardless, all developments in LED tech are great!
:) and :popcorn:
No further thoughts? I thought that a neutral white of this die size (probable) at 254lm minimum would be on the top of a lot of peoples list!:shrug:
HL
As a direct rival to the xp-e, which supposedly is available in 'outdoor-white' which covers the gamut from warm-white to cool-white, which is available in R2+.
A lot of folks prefer the efficiency of the Cree XP series over the better beam quality (IMO) of the Lumileds Rebel.
120 lumens at 350 mA is a good step forward from Lumileds.
I'll have to watch for these when they are available from the dealer I get my Rebels from.
Note that this emitter is the 'ANSI' / reduced CRI version.
In order to compare 'apples to apples' you should be fair and compare the regular Rebel to standard Crees. The Rebel is getting a boost here by not having to produce as much amber and compenstating for it by boosting red.
Not sure anyone has noticed, but XP-E in R2 bins are still quite difficult to get, never mind R2+.
A 1mm2 die at 120 lumens if it has good availability is better than anything that Cree is producing right now.
The Rebel ES in neutral is 125 lumens at 350mA, however, it has a lower forward voltage so better efficiency.
Luxeons reduce less in output at high temps compared to Cree which gives a further boost at high drive levels compared to Cree.
Semiman
I fail to see how this 65 CRI Rebel part is better than the higher output(122lm minimum) higher CRI(75) Cree XP-E R3. This bin is available in massive quantities if you just ask for it. You can buy them from Cutter all day long. The one thing that Rebel has that the XP-E does not is a neutral white at those outputs. I have not seen this particular part in action so don't know if the drop in CRI is worth the extra output it provides. I'll buy a few when I have some more money.
Ah yes..the troubles afforded by naming two different parts by the same name.:shakehead I assume you are now talking about the larger die version? If so then we would need to compare to the XP-G which beats this particular Rebel in efficiency.
Semiman
Has anyone done any independent testing of this to see if it is true?
All this is rather academic at this point though as Lumileds has all but caught up with Cree.
Yes, I do know they reduce less at high temp. It is an easy test.
Cutter has low volumes of R3. Try putting in an order for any sort of volume with any sort of bin consistency. Even with the R2 that is pretty tough.
I was not comparing the Rebel-ES to the XPG.
I am also not "blinded" by Cree and can still think for myself, something that seems to be missing by many on here.
I don't think I make the Cree groupies feel warm and fuzzy either...:green:
However, the fact is that the Rebel has gained some efficiency by tossing some visual spectrum out the window. Its just not logical to compare this emitter to other neutrals running a higher CRI, including other Rebels.
I can think of two reasons for this. The most obvious is to get higher specs on cheap luminaires that can claim improved efficiency at neutral temps. 'CRI? We don't need no stinkin CRI' This way the Rebel can encroach on more of Cree's market share. I'm not entirely sure what the entire 'ANSI' binning scheme is either, or maybe I don't want to know.
Next, and this is more theoretical, but Luxeon is claiming a big efficiency jump with amber. Which means they might be following Cree's strategy in that if you want improved CRI *and* efficiency then use a dual emitter approach in higher end fixtures.
The added red should improve color clarity compared to cool-whites for flash-light use though. For the first time I'm actually interested in seeing what the impressions are of this emitter in nigtht beam shots.
Well lets see the results then.
I highly doubt it would be a problem getting them. Not saying you have to go through Cutter either as I seem to remember that if you are big enough you can go straight to Cree. Tried that?
That's my point. You should. Why you say? Because you were quoting data from the larger die Rebel ES's datasheet. That data point is not listed in the small die Rebel ES datasheet. The large die ES is the same size as the XP-G.
I was also making reference to the stupidity on Lumileds part on naming two LEDs by the same name.
Excuse me? I know you are not referring to me.:tsk: I like Cree as a company but I hold everyone's products to the same standard. I venture to say there is no one person here that knows more than me about all the major LED products all the way down to the technology used at the die level. I have put a ton of time, effort, and money buying and testing LEDs from all the major brands. I have been Cree-centric from a product standpoint because there is no production LED in the world that can beat the XR-E for my application. None. There are however other applications and in a product that I will be releasing soon you will see that I am anything but bound by conventional thinking. hint-not Cree
Did you even read the last line of my post you quoted? Just wondering.
I saw you mention this before but didn't say anything. I'm a bit perplexed by that statement as I was under the impression that they got better efficiency buy reducing the red not increasing it. There is more loss involved with down-converting to red than yellow so it would seem a bit counterproductive to trade yellow for red. Did I miss something?
I would have no problem venturing that I have every bit as much if not more knowledge about LED products on the market, what is coming down the pipe, and yes how LEDs work all the way down to the die level. That is the benefit to working with them on both a technical and business level virtually as long as high powered LEDs have existed and for a few years beyond that as well. It is also the benefit to having a corporate LED spend somewhere in the range of a million USD. No I am not going to reveal who I work for. I am on a first name basis with many senior people at Nichia, Lumileds, Cree, Seoul, Bridgelux, Luminous, etc. I don't mind sharing my opinion (and non NDA information) with the community, but I need to maintain my relationships too.
I think if you read through my posts it is obvious I know what I am talking about.
I made a quick comment about the Rebel-ES to clarify what I was talking about. The object of my post was not to compare the ES to the XPG.
In terms of availability of the R3 bin and "just asking for it" from Cree, I have done that. Your comment "I seem to remember that if you are big enough you can go straight to Cree" ... tells me that you are not that tied into what is available. My comment about availability comes from those discussions. Yes I can get them, but not in the consistency and price range I need. I am still waiting on similar confirmation from Lumileds on the 120 bin Rebels.
By massive quantities do you mean 100's or 10's (or 100's) of thousands? Cutter is not a high volume distributor. When I consider volume I mean at a minimum 10's of thousands.
Since you are comparing to a R3 bin Cree (CRI 75), you really need to compare to a 120 lumen Rebel cool white CRI 70. Lumileds generally does poor on their lower CRI parts because they have a hole at 460-490nm. At longer wavelengths their phosphor tracks pretty well with Crees.
We use XRE as well in a few of our legacy products and will not be changing them due to the unique optical properties which no one seems to be replicating except perhaps OSRAM.
In terms of the heat degradation between XPE/Rebel, since you do some many tests, you should have this already... ;-) ... We have a somewhat proprietary die temp measurement system that pulses the die off for very short periods of time and uses a thermal camera to measure the package and into the die during these periods. The off time is very short to ensure the temp is consistent. The techniques we use are somewhat like lock in thermography in order to get high accuracy. That is about as much detail as I can reveal.
For most of our products the output versus die temp does not make make of a difference in output, but for some of our specialty products where we drive them hard, it does start to impact performance. This would not be unlike the high performance flashlights that people on CPF like to play with hence my comment.
The other issues I run into with the XPE and XPG (not XRE) is that I am somewhat forced into a metal core board for higher temp and drive products. The Rebel is far more amenable to a FR4 with vias thermal design while still achieving very good thermal transfer results. That lets me keep my costs down for most of my products. My customers are still more concerned about dollars/lumen versus lumens/watts for 90% as long as the product has reasonably good efficiency. They also like consistency of color and hence Nichia tends to be a strong player for us for mainly warm white. We are split pretty equally between Cree, Lumileds and Nichia with a few niche products based on other LEDS.
Semiman
Semiman
I really don't have the time to go in great depth here so let's run through this quickly and move on.
At no time did I attempt to disparage your knowledge base unlike your insinuation towards me with your "I am also not "blinded" by Cree and can still think for myself," comment. That was about as off-base a comment as one could conceive. Sure I'm not a big player in the market. I'm not even on the map but that hasn't stopped me from developing my own advanced LED packaging technology among other things. 95% of my stuff has not been seen by this community so don't draw conclusions from the 5% you see. If I have made comments as to the excellence of Cree product it is because it is an excellent product. That must also be taken in the proper context of this site and its main purpose of portable lighting not the fixed lighting you work in.
I work in fixed and ultra efficient battery powered lighting ... but I digress.
