Lumintop SD26vn - Smallest 26650 Thrower
eekazum
You forgot to mention that the R50vnP (or variant) comes with its own 26650 battery! However, the normal R50vns don't come with driverVNX2.
80k lux got my interest tho. Relative to spill, how big is the hotspot?
wimmer21
Kentucky
Order placed.
I would love to purchase an R50 Pro tail cap for my R50vn... to make it shorter. Not sure if that's a possibility.
wimmer21
Kentucky
I know you're not asking me, but Vinh said on his vid that it has a really big, we'll defined hot spot. That comment is what sold me on the light.
Capolini
Banned
Valley Forge, Pa.
I watched that video also. Looks like a great light,,,,,,,,I just can't justify it now,,,maybe later!
It has the throw of my TX25C2vn XPG V3 DD SINGLE MODE[TWIST/UNTWIST TAIL CAP TO ACTIVATE!],,,, ~ 900 LUMENS/Field tested @ 80Kcd
The SD26vn also has 80Kcd plus 500 additional lumens/bigger hot spot and about the same length. :thumbsup: The SD26vn is 3/32" longer!
vinhnguyen54
CPFBA
Um...hopefully video beam shots will show...
SCEMan
Treasure Valley, ID
Order placed.
How short do you need it?
I considered this too, but realized in my (medium) hand, that if the body/tailcap length was any shorter I couldn't access the button properly.
wimmer21
Kentucky
no spares :-(
Ok, thanks for replying.
Hmm, I'm not sure I understand. I just picked up my R50vn and held it the way I normally do, then imagined it being five millimeters shorter... I don't see an issue. Maybe we hold our lights differently? I don't have large hands.
SCEMan
Treasure Valley, ID
I just gripped mine and I misspoke. The button isn't an issue for me, it would be my little finger losing grip on the tail cap as it barely fits now. I have the same issue with compact 1911's with beveled base grips.
wimmer21
Kentucky
I see what you mean now, and it does seem like it might be too short with the Pro tailcap. So I just picked up a smaller light with side switch and my pinky found its place naturally. Apparently I don't have that same issue.
wimmer21
Kentucky
Thanks for the pics! The Clicky on my R50vn broke last night. It switch still works, but no more clicky. :-(
cclight
I think you guys are taking the 5mm way too seriously.
For me it makes a difference, not because of the grip but in the pocket. If it were 5mm shorter it'd fit better there.
Pitty when I ordered mine this option wasn't yet available...
wimmer21
Kentucky
Yeah it's my fav light to hold in my hand while watching tv. I click off-on-off-on... but no more... I must have worn it out. Funny thing is it's the only light I've been that way with. I think there's probably a little bubble like thing inside that is stuck and won't pop back out. I don't know what to do except try to open it up and maybe fix it, or maybe ruin it completely.
Offgridled
Southern California
Give it a shot wim only way to learn. Easier than you think. :)
SG Hall
Sampson Flat, Sth. Aust.
This is a unique light! It doesn't really flood and doesn't really throw, but it's really appealing. I have many more suitable lights for any given job, but this is often the one I grab.
Good idea to pull it apart if you have some tool to do it with Steve. At very least you will learn something. I'm no mechanic, but I've pulled a few tail caps apart and fixed some of them. At very best you'll fix it, or give us some new material to work with. You just don't blow up things anymore....... [emoji16]
