Lumintop SDmini Flashlight - Utmost Comfort and Security
gearvita
Utilizing Cree's high intensity flag XP-L HD LED, the Lumintop SDmini flashlight deliveries max 1000lm output on single 18650 battery. Compared to other 18650 flashlights, SDmini is definitely smaller and more portable at just 11cm length and weighing only 88g. Moreover, the SDmini enjoys 7 modes, except the 4 brightness levels, the SDmini is equipped with 3 flash modes. Intelligent temperature regulation system allows the SDmini to adjust output performance according to its body temperature to ensure stable and safe operation.
Main Parameters:
Emitters: Cree XP-L HD
LED Lifespan: 50000h
Luminous Flux: 1000lm
Luminous Intensity: 12640cd
Beam Distance: 180 - 224m
Battery: 1 × 18650 or 2 × CR123A
Waterproof: IPX-8 standard
Impact Resistance: 1.5m
Output and Runtime:
Turbo: 1000 lumens ( 2 hours )
High: 575 lumens ( 3 hours )
Mid: 363 lumens ( 5.5 hours )
Low: 48 lumens ( 36 hours )
Strobe/SOS/Location Beacon: 1000 lumens ( / )
Product Features:
● Utilizes Cree XP-L HD LED with 50,000 hours lifetime.
● Single button side switch design provides one-handed operation and easy access to all functions.
● Intelligent Li-ion battery charging circuit, integrated Micro USB charging port is water, dust and impact resistant.
● Advanced temperature regulation system adjusts output performance according to its body temperature to ensure stable and safe operation.
● Impact resistance to 1.5 meters and waterproof in accordance with IPX-8 (submersible to 2 meters).
● Optimized ultra-precise reflector offers 224m far-reaching beam.
● Double-side AR coated tempered glass lens resists impact and thermal shock, maximizes light transmission up to 99%.
● High strength aerospace aluminum alloy construction with anti-scratching type HAIII military grade hard-anodized finish.
● Consistent silo integrated structure, to ensure the best heat dissipation.
● Runs on 1 × 18650 or 2 × CR123A battery.
● Reverse polarity protection to protect from improper battery installation.
● Intelligent memory function stores last mode accessed.
● High quality detachable stainless steel reversible clip.
● Innovative tube body design allows the clip changed directions in the same location.
● Anti-rolling design.
● Dual spring-loaded impact absorption mechanism.
● Capable of standing up securely on a flat surface to serve as a candle.
Get the SDmini on GearVita, hold it in hand, you will feel the utmost comfort and security: https://gearvita.com/lumintop-sdmini-led-flashlight-1000-lumens.html
You may like:
xiaomi redmi note 5
xiaomi mi 8 lite 128gb
