R
robk
I'm rather conservative and always use some resistance in the lights I put together, or use a DC-DC converter with some type of voltage or current regulation. My question is has anyone had catastrophic failures when direct driving a Lux III from 3 NiMH C or D cells (especially when "hot" off the charger)? I normally use 0.5 ohms just to limit the initial current draw to less than 1.2A or so, then it drops as the cells discharge. It seems to be common practice to direct drive the LIII's, but I was just wondering if anyone has run into problems.
Thanks- Rob
Thanks- Rob
