lux vs lumens vs candle power
Avatar28
Nashville, TN
What, exactly is the difference? Okay, lux is generally what is used to measure the throw of a light and lumens is more a measure of the overall amount of light put out. How about candlepower? For example, those 1,000,000 candlepower spotlights you see all over the place, how would they compare to a light measured in lumens?
Lux and CP are both light intensity at a specific distance (throw). Lumens is overall light output.
I would forget CP though. Concentrate on Lumens and Lux for a good measure of light output.
Lumens is the total light output in all directions
Candlepower (Candela) is the output over a certain angle. It is directly related to Lumens. 1 Lumen(Lm) = 1 Candela(Cd)/Steradian. (A complete sphere is 4*pi steradians). The difference is that the candlepower is usually measured at the brightest part of the beam to make the light look better. Lumens always measures the total light output.
Lux is a measure of how 'lit up' a surface is. 1 Lux = 1 Lumen per square meter. Unlike Lumens and candlepower, it depends on how far the light source is from the surface (unless you are talking about something like sunlight).
I just collect some infomation about the above question just now also, but here , all of you give us some hints,thanks all of you so much.
I guess this is a decent thread to ask this question. Are LED lumens any different than incan lumens? For example, if an LED is rated at 75 lumens and an incan is also rated at 75 lumens, would they be the same brightness? I'm not interested in colors, depth perception, etc. in this post. Just a question about lumens only.
While we are on this topic, who sells a good and affordable lumen/lux meter? If I buy one, does that make me an official flashaholic? :)
I have a good light meter for photography use, anyway to convert it's readings to lux/lumens etc?
Like at ISO 100, f16, 1/250th = 5,000lux or whatever.
Edit: Found my answer: http://www.sekonic.com/support/support_2.asp
Not sure how accurate it is, but I get about 464,000.00 lux from my P1D-CE on Turbo, holding it righ up to the sensor.
The official lumens rating is weighted for the eyes sensitivity to different colors. A chart is shown Here at Wikipedia
Peak day vision is for green light ~550 nm, while peak night vision is at cyan ~510 nm. This would tend to make LED's somewhat more visible for night vision as their color is 'cooler'. Also note that night vision is very insensitive to red light ~650 nm. That is why red lights are recommended to preserve night vision.
Here a couple of rather complete and clear explanations:
http://www.flashlightreviews.com/features/lux.htm
http://files.intl-lighttech.com/handbook.pdf
it takes a while to read the second one but it is probably wise to keep it ready for future reference.
I'm sorry but the flashlightreviews article is just wrong. It keeps referring to lux when it is really talking about candlepower. It is easy to confuse since lux is what his meter displays. The key point is - when talking about the lux of a light, you must specify the distance. For example a light that reads 100 lux at 1m would read 1 lux at 10 m. Lux is not the output of a light - it is a measure of how much that light illuminates the object it is shining on. Lux is the important measure for profesional lighting designers and photographers. If you are designing a lighting system for a football stadium, you don't care about the light itself - you care about evenly lighting the field to a certain specified lux level.
Consider 2 perfect lights. Both are 100 lumens. Both have a perfect square beam that is even with sharp edges. One has a 5 degree beam and the other has a 10 degree beam. If you shine both lights at a wall, with the 5 degree beam 11.5 meters away and the 10 degree beam 5.75 meters away, both lights will make identical 1 meter square 'spots' that are 100 lux (100 lumens/square meter). However the candlepower of the 5 degree beam is 4x that of the 10 degree beam since the light is concentrated in a slimmer beam that has 1/4 the cross sectional area at a given distance.
I'm sorry but the flashlightreviews article is just wrong. It keeps referring to lux when it is really talking about candlepower. It is easy to confuse since lux is what his meter displays. The key point is - when talking about the lux of a light, you must specify the distance. For example a light that reads 100 lux at 1m would read 10 lux at 10 m. Lux is not the output of a light - it is a measure of how much that light illuminates the object it is shining on. Lux is the important measure for profesional lighting designers and photographers. If you are designing a lighting system for a football stadium, you don't care about the light itself - you care about evenly lighting the field to a certain specified lux level.
If you'll take a closer look at the entire website, so that you understand the context in which that article was written, you'll find that he is correctly talking about lux readings. Heck, the very principles that you are using here are the basis for his measurements. :shakehead
In fact, Doug uses the inverse square law to derive his throw ratings, which is one of the most useful techniques I've seen for objectively evaluating lights. And it's all documented on his website.
For the most part on CPF, when you see lux measurements, they are taken at 1 meter. Otherwise, the measurements are meaningless, as you point out. After a while, though, most of CPF understands that 1 meter is the commonly-accepted distance to measure at, so it's often left off.
That article assumes all measurements are taken at the same distance. I think that if you re-read it, keeping that assumption in mind, that you'll find it's correct.
I completely agree with the thrust of the artical. If it had said '200 lux at 1 meter' instead of just '200 lux' I would have no argument. I am bit touchy about manufacturers who rate their lights in candlepower without specifying the beam width. It encourages the creation of lights with needle thin beams that impresses your friends but is almost useless as a practical light (unless you are using in a boat or such on objects a mile away). A laser has a candlepower rating that is off the chart, but I think most of us would agree they make very poor flashlights.
...I am bit touchy about manufacturers who rate their lights in candlepower without specifying the beam width....
LOL - I think that's true about most CPF members, so welcome aboard!:D
Hello OhMyGosh,
Welcome to CPF.
A point of clearification...
Foot candles and lux measure the same thing. One is English and the measurement is normalized to 1 foot, the other is Metric and the measurement is normalized to 1 meter.
You can transfer between the two measurements by using the following conversions:
1 lux = 0.0929 fc, or going the other way
1 fc = 10.764 lux.
This means that with 1 fc of illumination, you have 1 lumen per square foot, but when you move out to 1 meter for a lux measurement, you end up with only 0.0929 lumens per square foot due to the inverse square law and the greater distance.
Here is a thread where we compared various light meters, and got into some deeper discussions about light measurement.
Tom
.... For example a light that reads 100 lux at 1m would read 10 lux at 10 m.
Actually (sorry the pedant in me got out again) a light that reads 100 lux at 1m would read 1 lux at 10 m, according to the inverse square law. 10x the distance so 1/10^2 (1/100) the light intensity.
You know I noticed that after I fixed the same error in the last sentence. I perversely decided to leave the error in to see if anyone would notice - congrats:twothumbs
LUMENS:
A *******ized measurement that at one time meant total light output of a light producing device. It is now a marketing buzzword.
LUX:
A *******ized measurement of light intensity that gets used incorrectly to compare lights.
CANDLEPOWER:
At one time, centuries ago, this actually existed, now it is nothing more than a *******ized marketing buzzword with absolutely no meaning or correlation to anything whatsoever.
LUMENS:
LUX:
CANDLEPOWER:
Geez, Mr. Grumpy. :devil:
I'm just kidding. When I consider some topic about which I'm particularly well-informed, and the frustration I feel at all the limitations of various evaluative methods and comparisons, I get pretty irritated. Your credentials on this topic are beyond question, sir; so I hope you don't mind a little good-natured teasing from someone who doesn't know a tenth of what you do on the subject. :wave:
-Winston
yea, just jokin around mostly. but jokes are funny because of the truth that lies within. :) muaha
another thought on the subject...
candlepower is the modern day "watts" in audio gear.
Nowadays, they are always trying to sell you more watts, as if more watts is really the answer to your audio problems, when in fact, the numbers on that garbage in the typical department store are total lies. It's the same thing with candlepower. If the customer were accidentally informed that if they picked out speakers that are 3db more efficient, they could get away with HALF the amplifier, then how would they sell big over-rated amps to unsuspecting victims? lol... Or if you accidentally informed the customer that the average listener will never listen to an audio program at more than ~2 watts per channel. Suddenly the huge buzzwords mean nothing.
