luxeon 3's BIN'd for 3.9-4.23 Volts?
elfen1
luxeon 3\'s BIN\'d for 3.9-4.23 Volts?
Anyone have these or seen them arounf or know where to get them?
L
LITEmania
Guest
Re: luxeon 3\'s BIN\'d for 3.9-4.23 Volts?
Vf M : 3.99-4.23 is very rare.
I hv some L Vf : 3.75-3.99
SY0L
Warren
L
LITEmania
Guest
oops! Fred is selling here tw0m
elfen1
I have an emitter thats pulling 3.9 when I measured it on each tab beside the dome. I'm not sure if they can go up to any voltage or if the Vf basically limits the amount>?
L
LITEmania
Guest
L Bin shows 700mA at 3.9V and 1000mA at 4.1V
I don't think this is an issue for the flashlight unless you run it 2 or 3hours continuous other than batteries.
But fare well heat sink is essential..
3rd_shift
DFW. TX. U.S.A. Earth
[ QUOTE ]
[/ QUOTE ]
What will you be using these for anyways?
Just curious. /ubbthreads/images/graemlins/wink.gif
elfen1
4 a 4 star mag conversion using 4Dcells 9000Mah each.Sorry about the type I have a newborn Z& onlty 1 hand avail!!!
wasBlinded
Oklahoma
Don't forget that even if you have an LED that starts out with a high Vf, the Vf will drop with use over time, with the biggest drop coming in the first 24 hours of burn time. So if you make a direct drive light with one of these, you should periodically retest the current draw to make sure it is not pulling more current than you expected.
The drop in Vf with high Vf LEDs is much more dramatic than with low Vf LEDs.
Ny0ng1
Singapore
wasBlinded: any example of the margin of the drop for L or K Vf?
for e.g. 3.9V to ?.??V after 24hours?
TIA
wasBlinded
Oklahoma
The amount of drop varied between samples. Typical was a 0.15 volt drop, but some eventually dropped as much as 0.3 volts. This can result in big current increases in direct drive situations. You can see the thread yourself here: Vf shift
