Hi and thanks everyone for the great help with this issue...
KevinL:
That's a very interesting idea for sure, and i'd like to try it.
The only thing i would worry about (and i had this same worry
when using superglue for gluing cracked magnetic inductor cores
back together after cracking to form a small air gap) is what
is the temperature rating of the superglue? If the Lux gets
warm does the superglue soften up much, and if so what temperature?
Then again, i guess i'd have to ask this same question about
thermal epoxy too. I know regular epoxy melts at some temperature
as it acts like plastic.
Any ideas about the super glue temperature melt (or soften) point?
Doug Owen,
I guess 15 bucks isnt that bad. I should prob get some anyway for
future use too.
Yeah, i was hoping there's an 'edge' to catch the wire on. I was
even thinking of soldering the ends of the wire to the clad which
would make it easy to repair too.
I like Kevin's idea about glue after HS compound too, but i'll pose
the same question to you as to him...
What do you think the temperature rating of super glue (soften)
would be?
I like your idea of using 'normal' epoxy too, as i have some
PCII which has a fairly high temp rating. Would have to be clamped
very tightly overnight for cure. The only worry after that is
'thermal pumping', which i think a spring clamp handles a little
better.
Pablo:
Thanks very much Pablo, i really appreciate it. I'll try the pcb
idea first and see how it goes and maybe save you the time.
I could even pick up a piece of copper bar which would conduct like crazy /ubbthreads/images/graemlins/smile.gif
Havent some people even used a copper US penny?
lambda:
Wow, that sounds interesting. I'd be afraid that the grease would
interfere with the proper curing of the epoxy however. Have you ever
tried this on an actual LED and if so how well did it work at 350ma?
I've mixed paint with epoxy and even silicone rubber to keep it
a little flexible, but that was with very small amounts.
robk:
Oh, that sounds pretty good...i'll do a search...thanks.
Oh ok, i wont have to do a search /ubbthreads/images/graemlins/smile.gif Thanks!
Take care,
Al
