[ QUOTE ]
Anglepoise said:
With my Fluke set to read continuity, and one probe on the emmiter base and the other on ,first the + and then the -, I got no reading.
Doug. Is this considered isolated? I am confused.
[/ QUOTE ]
You need to use the diode test function of your DMM. Put the + on the emitter base, and the - at either of the power leads - if you have contact, it should indicate current flowing and/or (depending on your meter) show the foward voltage of the ESD diodes. If you get nothing, then things are isolated.
[/ QUOTE ]
