Here are my calculations and extrapolated data for the minimag and badboy running 400mA through a 1W Luxeon with a Vf of 3.4V.
The minimag thermally stabilized to 115F on the case in ambient 25C room temperature.
From this and from the total power being drawn we can now compute the Thermal Resistance of the flashlight body to Air (Rfba).
The total power is (V * I) / efficiency = (3.4V * 400mA ) / 0.85% = 1.6W total.
Using the equation Rfba = (Tfb -Ta) / Total_power = (115F - 77F) / 1.6W = 23.75 F/W = 13.19 C/W.
Where:
Tfb is the Temperature of the Flashlight Body (we measured 46.1C (115F))
Ta = Temperature of Ambient or 25C (77F)
Rfba = Thermal Resistance of Flashlight Body in degrees Centigrade per Watt.
(This means if there was 1W of power the flashlight body would rise 13.19C above ambient. Two watts the flashlight body would rise twice this. etc etc etc...)
Armed now with 13.19 C/W Rfba we can now compute our worst case Luxeon die temperature for the Badboy minimag mod.
The three thermal resistances are:
Rfba = Thermal resistance of Flashlight body. 13.19 C/W.
Rbbfb = Thermal resistance of badboy board to flashlight body. (Assume 15 C/W)
Rslg = Thermal Resistance of Luxeon emitter aluminum slug. (15 C/W)
For the 400mA badboy we know we have 1.6W so the die temperature is the ambient plus the sum of the thermal resistances of each junction.
Ta + TRba + Tbbfb + Tslg = 25C + (1.6W * 13.19) + (1.6 * 15) + (1.6 * 15) = Tdie = 94 C
This is the nominal. Now worst case would be on a hot day at 110F or 43.3C.
Ta + TRba + Tbbfb + Tslg = 43.33C + (1.6W * 13.19) + (1.6 * 15) + (1.6 * 15) = Tdie = 112C
So, worst case we have not exceeded the 125C of the die of the emitter and we are operating the die more than 10C even under the worst case of 110F.
Now let's do some quick computations for 500mA or our Badboy_500 mod.
The thermal resistance model is similar with the exception that we are now pushing 2.05W in total.
I'll only compute the worst case as an example.
Ta + TRba + Tbbfb + Tslg = 43.33C + (2.05W * 13.19) + (2.05 * 15) + (2.05 * 15) = Tdie = 131.86C
This means that we are overtemping the Luxeon by 6.86C. TO keep from exceeding specifications we would need to drop our maximum temperature specifications of 110F by at least 6C or more.
Subtracting 10C for safety from the 125C die specification I calculate that the Badboy_500 in the minimag I have will be safe up to 26.46C or 79F.
NOTE: These calculations are for zero air flow. Moving the flashlight increases the air flow across the flashlight and significantly lowers the Thermal resistance of the flashlight body to ambient air.
Conclusion:
I hope this helps modders who are now working with the new 5W to be inspired to make the effort to ensure that they don't over drive and shorten the 5W Luxeon dies expected life.
This now confirms my belief that driving more than 500mA of constant current into a typical 1W luxeon is doing more harm overdriving the Luxeon for more light. The current 500mA can push the die past the LEDs die temperature rating and the Badboy_violet would definitely be doing some serious harm to the LED and overtemping it.
BTW: My calculations for the 5W greenie in the Surefire M2 housing is 10.88F/W (6.05 C/W)
This is based on 135F flashlight body temperature, 666mA Luxeon current, 6.8V Vf, and 85% efficiency.
Maybe, Doug S can verify the correctness of this post.
Where:
Conclusion:
