teststrips
I just recieved my first luxeon from a very friendly and good natured friend from the threads (dimwatt). It looks exactly like this one - link
I've worked with many regualar 5mm and 3mm leds in adding them to my PC, swapping better/whiter/brigher leds into my led flashlights, and I even modded my first solitaire. But to get right down to it, i don't know a thing about these luxeons. I can see 4 basic traces from the pic that I linked to.
top left - very small eyelet
bottom left - leg 1
top right - leg 2
and the other trace is on the bottom, and I'm assuming it's for heatsinking purposes.
also how much voltage/current would I need to feed this thing?
I figured to make this 1st luxeon mod as easy as possible I'm going to put it into my biggest light (which sucks as a huge incan) - a 3 "D" cell craftsman.
If you could also point me in the right direction on if I'll just need a resistor to Direct drive this thing, or if I'll need a more complicated circuit.
Sorry for all the newbee talk, I've tried searching, and found the feature almost completely worthless. Adding a + for a 2nd search criteria usualy does not work at all for me, it usually just searches like an "or" search on google anyways.
bottom left - leg 1
top right - leg 2
