Calina
Your calculations are correct as far as resistors are concerned. They will have to be fairly big resistors, .5 W will do but barely, you'd be better off with 1 W.
I hope your aquarium is huge because this is going to be bright, about equivalent to a 150 W incandescent bulb.
I don't understand why you insist on using Rebels. They will be extremely hard to work with because of their size and SMD caracteristics. Cree would be easier to use or Lux lll if you don't mind a little less light. Your design will have to take into account the heat generated by your 16 LEDs.
It will certainly keep your fishes warm.
