<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by videocal:
-Am I correct in assuming that the Luxeon module operating out in the open, by itself, and with proper voltage, will not overheat?<HR></BLOCKQUOTE>
I'm always a bit shocked at how hot these darn things run, even at their "typical" voltage". I have had to heat sink and ventilate all of my conversions with them so far; {all in non-metallic bodies (still haven't done a Maglight conversion yet
I think that in a metal body you may not have to ventillate with PROPER heat sinking... )}.
Anyway, you SHOULD be ok with the module in open air with the voltage at no more than "Typical" (as long as the ambient air temp stays under 95-100F although I'm just guessing about this part).
I just started a 2 D cell test on an amber LS - In open air (80 F) with moderate air circulation, no heat sink it is running at about 72 C- too hot to hold without gritting your teeth
, but within the limits set by the manufacturer. (75C operating temp with optics, {105C PCB temp})
However, if you cut off the air flow the temp goes way over 80C (that's where I quit testing). NOT good in my opinion.
On one of those neat round heatsinks that I found at All Electronics (I posted the URL to them on an earlier thread), the LS stays under 57C in open circulating 80F (27C) air and about 65C with no circulation.
These measurements were taken with a 2.98V "no load" supply, with the LS drawing 224mA @ 2.74V
So, bottom line in my opinion: Heatsink whenever possible, have good airflow around the aluminum base of the module unless you have a GREAT heatsink that is able to transfer heat to the "outside".
This is with "constant" power. Intermittant use or Pulsed power supplies will change that - I don't know how significantly since I haven't personally done any work with them yet.
