ElektroLumens
Luxeon Star, Homemad Copper Flashlight, 3 \'C\' Cells. (CopperLux)
I made another copper flashlight, which I call the 'CopperLux'. This flashlight is made of common one inch copper pipe, cap, and connector. It has 3 'C' cell batteries with one ohm resistance. No voltage regulator is used.
The flashlight has a high brightness and low brightness setting. Low brightness setting uses more resistance to dim the light. I put this low brightness setting in this flashlight because often times low brightness is preferable.
The Luxeon Star LED heat sink plate is trimmed, and epoxied onto a aluminum heat sink, which is pressed into the head, and wired to the switch.
Here's a photo:
Wayne www.elektrolumens.com
Here's a photo:
