Streak
I have read many CPF articles about the LS and how to prevent frying it. I have managed to get hold of one to play with and have some questions.
One CPF member sais that he fed his LS at 3.4v and 870mA. How is this achievable? I fed about 5 volts into mine with no resistor and only got about 300mA. Others have achieved 300mA with 3.2v. How can I be exceeding the suggested Vf of 3.42v with no resistor and not achieving 350mA?
Am I missing something here, forgot how Ohm's law works or am I miss reading my Fluke 77?? Set on 300mA scale and in series with the positive. I know the 300mA scale has a shunt in circuit which could give false readings. Should I be using the 10A scale instead?
The application sheet for the LS says that with a 6v battery pack you should use either an 11 or 8 ohm (depending on ranking) resistor to keep currents down to 350mA. Applying Ohm's law that should mean 5.5 ohms at say 3 volts and 8.25 ohms at 4.5 volts.
However at 3 volts being below Vf and current below 350mA there should be no need for the series resistor.
I have been using a mini PWM circuit driven by 6 NiCd and a 20 ohm resistor in series with the LS, to control brightness. I guess I could just as well use 3 NiCds and a 10 ohm resistor to get the same results??
Lots of questions, lots of rambling. Help me understand.
Thanks.
Thanks.
