LuxV vs MC-E questions
FredM
Houston, TX
The LuxV was setup in a 2S2P config correct? So any driver that will work for a LuxV will also work for a Cree MC-E in a 2S/2P setup?
How different will the heat sink need to be going from the LuxV to the MC-E?
I don't know for sure but it should be possible to wire a MC-E in 2S2P and power it off a LuxV driver.
Heatsink need should be less because the MC-E is more efficient.
Hi - I am a long time fan of the Lux V, but the Cree part does look interesting. Any links to the Vf of that part ? It does not look like Cree specs Vf, which is a big deal to my method of building lights.
Thanks
Harry
what about the footprint of the LuxV vs the MC-E? Pretty similar sized or totally different?
(Left to Right: P7/MC-E/XR-E/GDP/LuxV)
Very nice collection!
Does the MC-E magnify the dice with the dome? If so, I imagine the reflector needed is quite different than the P7.
What are your findings using the MC-E?
Thanks
Harry
Seems to be about 3.2V per die at 700mA.
Cree doesn't list the MC-E Vf because the dies are individually addressable. It can be 12.8V@700mA, [email protected], or [email protected].
The Vf for the MC-E isn't listed because Cree dosent bin for Vf.
They list the Vf as a range,even on the single die emitters.
MC-E Vf range below;
-Michael
