Re: Mag 3300L
Is the switch capable of 5 amps? Is it long enough for 2 65mm cells?
Mac
The switch will be VanIsleDSM's newly introduced
FETtie and it is supposed to handle 25 amps. The host is designed for 2x
26500 cells
not 2x26650, but I use IMR LiMN chemistry Li-Ion cells so they should deliver sufficient voltage and amperage.
My concern is contact with the batteries. The host itself seems to have been designed for
FM's G4 bi-pin socket. When I tried an ROP bulb instead of the socket, I had to use a magnet in between the cells to make electrical contact for the ROP to operate. I'm wondering if there was a way to make sure your drop-in worked with the
FM host. I like its form factor because it is basically a 26mm bored 2C light that uses a Mag D head.
Thanks Mac for your consideration on my odd setup.
Just thought about it again and the ROP setup I described above may have been using the McClicky in the tail and not the FETtie in the tail right now (FETtie has longer spring than McClicky). I'll have to experiment tomorrow to see if I get different results.
Finally got to test the host again with my ROP bulb and so far no connection issues with the battery and the FETtie switch.
Therefore,
please add me to the list of people interested in a Neutral drop-in.
