Megalamuffin
Would anyone happen to have both of these for a side by side comparison? If so which do you prefer and why?
I have several versions of the M61 with 219b 4000K (M61, M61L, and M361), as well as two samples of the MDC LMH with SST-20 4000K.
Basically what's been explained so far matches my experience. The 219b drop-ins are a little less bright than the SST-20 heads, but the tint is more pink than green. They're otherwise nearly identical.
I put minus green filters behind the windows on the SST-20 MDC heads and now they're nearly indistinguishable from the 219b drop-ins. Same beam pattern, same tint, same brightness.
Here's a comparison:
f/8 1/320
ISO 1600
WB 5000K
Excellent! Thanks for the quick response. I couldn't agree with you more, well, except I like the Nichia tint just fine...Nichia doesn’t do well in 16mm heads, and in my opinion isn’t great in the 22 either. Sold my drop ins and mdc heads. Sst20 is good in either one and comparable to xpg2 but with better color. No rings! And no pink.
