most reliable will be a 17670, also happens to have more stored energy than a pair of RCR123s, so is the better option on both fronts. Another advantage of a single 17670 is, you can charge a pair of them on a 2 bay charger at the same time, enough for 2 "refills" so to speak, while the same charger would also be limited to 2 RCR123s, so you would only get one "refill" for a swap on the charger. Larger size li-ion cells like the 17670 tend to have a better track record than the little RCR123s, not a huge difference. but worth noting
[edit in]
I just read a review on this light and discovered that it, like many other lights that support everything from a single li-ion up to 2 li-ion voltage input, will not maintain true regulated output on the single 17670 cell. This is unfortunate as the description suggests that it might. With this thought in mind, the answer to the original question becomes kind of a tossup depending on a combination of factors:
here's a link to the review with this info:
http://www.light-reviews.com/tiablo_ma6/review.html
1. If you would like the longest possible rechargeable runtime, and don't mind the light dimming through the run, then a single 17670 is the best bet, providing about 2.5 hours runtime on high, over 6 hours on medium, and almost 18 hours on low. The output on medium and low with a 17670 is relatively flat until the end, the output on high steadily drops from 100% to 50% output through the run.
2. If you would like to have the same solid level of output through the duration of the run, then a pair of 3.7V RCR123s will be your best bet. Just make sure to get cells with protection as this light will over-discharge a pair of li-ion cells without any warning. (AW, BatteryStation, Trustfire white label, take your pick) Expect runtime on high around an hour, runtime on medium about 2 hours, and runtime on low about 5 hours. These runtimes are just my best guess estimates based on extrapolations from the tests that were performed on the light in the link above. But On high it will hold the highest level of output through the run.
