IanJ
So, I'm thinking about building an airplane. Nothing too fancy, just a little biplane. The one I've picked (a Ragwing Special II, most likely) is light weight and lightly powered, so anywhere I can save weight is worth it.
This brings me to areas where I have more experience. Specifically, electronics.
One thing I want to do is fly at night. As far as I know right now, the FAA doesn't have any requirements for landing lights for Experimental Homebuilt class planes (which is what this would be). In fact, if I recall correctly, to be legal for night flight, you don't even have to have a landing light. But I want one.
You see where I'm going with all this.
What's the best choice for emitters these days? Optics? Controllers? I will have a 12v system, just like on a car (using many similar parts). I was thinking a set of N (maybe 6?) Crees driven at 700 mA each, on a strip shooting through the prop. That guarantees a heavy flow of air, so cooling is basically a no-brainer -- put 'em on something that conducts heat, and make sure it has a couple fins. I'll never fly over about 5000 feet, so the air will never thin appreciably enough to worry about.
A miniscule amount of research suggests that landing lights typically produce 650 to 3000 lumens, more light obviously being better. How much light does a typical Cree produce? I read Fenix claiming 135 lumens, but I don't know if that's true or not (the difference between a "135 lumen" Fenix P1D-CE and my 42 lumen HDS EDC wasn't very dramatic). If I can really get 135 lumens out of a Cree, then 6 emitters with 15 degree optics (do you use optics with Crees? seems like you would, but that's why I'm asking here) would produce enough light to be practical (810 lumens), especially on a slow biplane.
Thoughts? Am I crazy?
(For reference, a typical landing light weighs in around a couple pounds, and the bulb lasts ~10 hours of operation, costing $20-100 to replace, typically. An LED system would not only save weight on bulbs, but also on wires (less current to pass), and would have a replacement time around the time the sun goes out.)
