EvilLithiumMan
I found a couple threads here telling of a quick and useful mod - put 3 CR123A cells into a Mag 2C and use them to overdrive a Radio Shack KPR112 bulb. I loved it. (I too favor the form and balance of the 2C). But being the evil guy I am, I'm not particularly fond of feeding CR123's every hour and a half to my flashlight. So I thought I would try to shove a pair of 18650 lithium ion cells into the 2C.
As it turns out, shove is definitely the operative term here. The two 18650 cells make for a tight lengthwise fit.
Two 18650 cells, plus a li-ion protection circuit from a discarded Canon BP511 pack make up the mod:
It is inconvenient to remove the pack for charging, so I made a 'charging adapter' from a PR bulb base:
How has it all turned out? - well, not too good actually. When I started, I wasn't using a fully charged battery so the KPR112's had no problem. But it turns out a full 8.4 volts on the pack will flash the bulb. I have flashed four of them now in an attempt to 'dial in' what voltage is the limit. The KPR118 (7.2v @ 600ma) works fine, but it isn't really being overdriven. (Although it does seem quite bright). At any rate, I guess until I achive decent reliability from the KPR112, the mod is a failure. /ubbthreads/images/graemlins/frown.gif
But I had a lot of fun, didn't I?
