D
**DONOTDELETE**
Guest
SUCCESS!!! I received the LS modules friday (3 white and 1 green). I used two whites and what I thought was an amber. When I found out it was green I switched to 3 whites. I left them on their bases and trimmed the bases with metal shears to fit. That was easy. I left the two corners with solder contacts in place and trimmed off the others. They ended up eye shaped. I purchased some thin copper plate and cut that to fit inside the Mag head. I cut a small hole in the center to put the wires through. I soldered the LS modules together in parallel. I put 3 3.6ohm resisters in parallel. This gave me 1.2 ohms. I broke a mag bulb and soldered the wires to it. It all fits inside the Mag head PERFECTLY. I turned it on
ITS BRIGHT!.
BEAM QUALITY: It produces a nice white beam that is fuzzy-edged. It is perfect for walking around at night. It doesn't throw a long-distance beam like a mag can. The beam looks very white like it is fluorecent.
OK so how does it compare to a regular mag 3D? Sorry guys,
the mag is still a *little bit* brighter. The edges of the Mag beam are sharp. The conversion has a much softer-edged beam. I hope to put some pictures up. I don't have a digital camera but I will shoot a shot with my 35mm with the new LS conversion vs. a mag 3D and scan it.
HEAT. The copper plate is doing a good job of sinking the heat to the Mag head. The head does get quite warm after 10 minutes. I will be looking around for some heat-sink compound.
RESISTORS: The resistors I used are not quite right. My calculations show that it is pulling about 1 amp through those three .25 watt resistors
. That turns out to be about .4 watts each. It is also right at the maximum amps that the LS modules can handle (with fresh batteries). I will be changing to four 6 ohm resistors in parallel for 1.5 ohms.
Does anyone know of a step down module that can handle 4.5v input, and output 1 amp at 3.5 volts?
FUTURE: I wanted to try an amber module in there but
Peter sent me one green by mistake. The green was not a good addition to the light. I think one amber would be a very good idea. The beam is currently white with a little blue tinge. A little amber would make it more pleasent to use and should be brighter.
