bmsmith
Ok, I poked around a little and did a search on Mag 5C, so I might have missed a prior post on this subject, but I'd love to try a Mag 5C light with 5 4500 mAh NiMH C cells installed and a 6V bulb with a high current rating (say 1.2 amps or more). Anyone tried this obvious configuration?
I suppose this would be an ok configuration if the reflector doesn't melt...
I'm not sure how much the voltage would drop on C size 4500 mAh NiMH cells under a 1200 mAh load... guessing an output of 1.05 - 1.10 Volts per cell once the initial peak is lost at the beginning of use?
Should this configuration be pretty bright, perhaps at or above UltraStinger levels? With the right bulb I'm guessing it'd have to be except for the darn crappy Mag reflector....
Thoughts?
- Brian
(This might be considered a mod I guess. Please move this there if so.)
Thoughts?
- Brian
