I am w/o soldering skills or a machine shop envinorment. This appears to make a rocker type install not for me unless there is a drop-in unit avaiable. Is there any easy-simple way to upgrade a Mag D Switch to better handle higher current levels? I would just use an AW Soft-Start Switch but these are not currently available. I am guessing that thin metal contacts & springs and plastic parts are the problem in handling heat & current in the stock switch? Wondered if anything that I could do to make switch last a little longer - of course would not be fail-safe,
