etc
OK, here is the story - I got the infamous intermittent blinking and flickering with this MagLED 2AA.
First, I checked the cells, they are Powerex 2700 MaH and were at 1.22 and 1.24V. Not low enough not to work and not a huge difference in voltage.
Then in my infinite wisdom I took some electrical parts cleaner spray and liberally applied it all over the light. I had previously cleaned the inside contacts with it some months ago (some drops on a Q-tip taped to a pen) so I thought some better therapy was necessary. I applied it not only to the insides but to all the threads, including the one on the head.
Well, the next morning the flickering got much worse and it would take more effort to twist it to turn on.
Upon examination I found this, the LED dim and loose and falling out. The liquid apparently ate through it and damaged things.
So, the moral of the story is - don't soak it in electrical parts cleaner if it starts flickering.
P.S. Can I still salvage it and put a better LED in it?
I EDCed this lite for months, ever since they came out with it.
Meanwhile, I will have to use the 3AA which is still LNIB (without usage)
