RedLED
What are the differences between the ML25LT, ML50L and ML50LX? All are 2 C cell lights.
Thanks,
RL
Thanks,
RL
Sambob,
What is your take on the two C cell lights? What do you use them for? I have wanted a C cell light for my truck, and for emergencies as since C cell lights are not common, batteries would be easy to get.
And, I was, like you thinking of running Eneloops with the C cell adapter.
Thanks again,
RL
I'm looking for a light for the car, been hemming and hawing over a lithium light but don't want to be worried if it gets knocked around or left in a cold/hot car.
ML50L/X looks like it might be a contender. Love my eneloops but never ran them in a C light. What type of run times are you getting with them vs. straight C's? I've also thought about NiMh C cells but experiences seem to be mixed.
Yup, the 2C ML25 is much like a fat Mini Mag LED – it's a twisty and can do the candle mode thing, but I find it is too bright to look at directly. Inside I just ceiling bounce it. The ML25's have some of the most useful beam patterns of any lights I am aware of – a huge spill just bright enough for most up close tasks and to keep you from stumbling around when walking at night without having to keep constantly scanning around with the light and the tight hot spot is great for distance. The original 2C ML25 was a single mode light rated at 177 lumens, there is a newer version out now that is rated at 192 lumens and has a low mode that seems to be around 25% on mine (I haven't found the official spec on this). These are a great bargain at under $20 at the wall of mart.
The ML50 has a bigger/ higher lumen xml series emitter and a slightly bigger reflector along with a multi-mode electronic side switch. The side switch makes the ML50 a good bit longer than the ML25. The ML50 can be easily programed to 1 of 4 "function sets" or groups of 3 modes (High/Low/Eco is the default but I keep mine programmed in mode 3 for Momentary/High/Eco). I find the eco mode is great for up close/indoors and really provides a ton of run time. Despite the higher lumens and larger reflector, the 2C ML50 is not quite as throwy as the ML25, but it's close.
Overall my 2C ML25 and ML50LX are 2 of my favorite lights. The 2C form factor is great, though I don't actually use C cell alkaline batteries. I run mostly AA Eneloops (or Ultimate Lithium Energizers when stored in a vehicle) and protected 18650's in adapters – I like the light weight of these cells and that there's no worries with leaks.
Instead of using 18650, you can use 21700 with 5000mAh
All it needs enlarged inside holder hole.
Thanks xxo! Going to try a 18650 in my ML50L tonight.
Regarding the Westinghouse batteries, I picked some up from WM a few years back, but 18500 LiPos, and they have worked well for some Surefire 9V incans I run. I can run them on freshly charged 18500x2 LiPo without fear of blowing them with 18500x2 Li-Ion or 18650x2 Li-Ion. Not much runtime due to capacity, but for around the house, it's cool.
Thanks again for the confirmation (on your 2C mags) with 18650 :thumbsup:
