DBee
Good morning all,
I couple of years ago a mate gave me his old Maglite 6D, which was manufactured in 1986. It was a bit battered and I had to strip and clean the contact points in the switch, as it was not operating smoothly. I also emailed Mag and they kindly sent me a new switch cover. I had an old incandescent bulb, which I fitted and it worked OK - apart from the fact that the beam was terrible - just a weak yellow blob of light with no spill at all.
Anyway, I purchased a TTS-ULT(10W) CREE XM-LS U3 drop-in all in one LED head and reflector from an online retailer here in the UK that I have used before, as well as a glass lens and it certainly improved things! It was advertised at 1000 lumens on high, with medium and low setting too. You lose the ability to focus the beam, but with this much light who cares? The flashlight was completely transformed, up to date and extremely useful and I keep it in the house as a security light as we live in a very rural location.
To keep the weight and cost down I run the 6D with 2 x AA rechargeable batteries in each of 6 adapters. The beam is great now and will easily light up trees 300-400+ feet away! It has a really nice hotspot and plenty of spill too. I would say it is comparable to the beam on my Mag ML300LX 2D.
The only problem is the size of the light - it's huge!
So my questing is this: Will this drop-in work in an old Mag 2D if I run it with 2 x 18650 batteries, and is this a good way to adapt it?
If it will, any ideas on what sort of run times I might get? With 6 D sized alkaline batteries this thing will run for many hours. On rechargeable AA's it will not run as long, but I only end up recharging them every few months, so not too bad.
If I can run this in a 2D body then obviously it will be easier to carry and will probably get a lot more use.
Thanks in advance for any advice.......and now for some pics! I can't find any decent outdoor beam shots (I know there are here somewhere) so I will take some more once it is dark tonight and add them.
