I have always wondered how the two would compare beam shot wise. Here are the specs:
6D Maglite xenon bulb
Lumens: 233.5
Runtime: 10-11 hrs (output goes way down as the power drains)
Malkoff 4-6D P4 Drop-in
Lumens: 240
Runtime: [FONT=verdana,arial,helvetica,sans-serif]8+ hours on 4 D Cells [/FONT][FONT=verdana,arial,helvetica,sans-serif]at the rated output (240 lumens). It will continue to operate at reduced output for several more hours[/FONT]. (maybe Gene can chime in to let us know how long the runtime would be with 6D batteries). Is it safe to assume if it runs for 8hrs on 4 that on 6 it would run about 12hrs?
Beam shots:
For the beamshots 2 different 2D hosts were used, and a mdocod 6aa adapter was used, the adapter was swapped into both hosts so both lights were running on the same power.
Indoors: Beamshots look to be very close, although the spill on the Malkoff is a lot brighter. In a completely pitch dark room the malkoff will illuminate everything like a lantern and still have a pencil beam for spot lighting. The xenon bulb has a decent spot beam, but hardly any spill.
XENON
MALKOFF
Outdoors: Difference in beamshots is more apparent here. YOu can see there is deffinately more spill on the MAlkoff and the xenon is not as bright. The xenon will also continue to get dimmer as runtime increases, where the malkoff will run at the rated lumens for 8 hrs.
XENON
MALKOFF
XENON
MALKOFF
Unfortunately, where the Malkoff REALLY excels is distance spotting, which was hard to do from my back yard. I will try to go to a field where I can show some distance beamshots a little better.
Lumens: 233.5
Lumens: 240
Beam shots:
XENON
MALKOFF
XENON
MALKOFF
XENON
MALKOFF
