Couldn't he put two dummy cells in there and use a 4D M*gLED drop-in? I'm sure with two lighter dummy cells you can change the balance of the light for a better swing :naughty:
Specifying output in "watts" can be misleading. Most of the maglite dropins for sale at Walmart, eg the "3 Watt LEDs" actually do use 3 watts of power from your batteries. The problem is they are basically obsolete emitters -- they are less than one-half as efficient as some of the newer LEDs available today, which can be just as bright (measured in lumens, or overall light output weighted by human eye sensitivity) yet only draw <1.5 watts. Or they can draw 3 watts and be 2x brighter.Prlce: NTE $20.
Bright: 2-5watt
I saw one today at WM called the Luxion 3watt for maglite at $18 but I didn't look to see if it would work with the 6D. I don't want to spend a fortune tuning up an $24 maglite. I want to upgrade the 6D cause I use it as a deterrent for BG's and errant dogs when I walk my own dog at night. I have a Husky 2D but it's not long enough for the above use.
C'mon Moderators... this Mag upgrade question is asked so often it is ridiculous. A dedicated sticky would mop up/prevent most of these threads from being started.
Prlce: NTE $20.
Bright: 2-5watt
$20?
Order this: http://www.lighthound.com/Pelican-Big-D-Rechargeable-Lamp-Set-FL-3854_p_1506.html maybe this as well: http://www.lighthound.com/521mm-UCL-Lens-for-Mag-C-amp-D-Size-Flashlights_p_44.html
That should give you a good bright light without blowing your budget.
Hey Cydonia, chill out before you go
Mod's since Cydonia is complaining, why don't you just lock this thread?
Or better still....delete it!:wave:
