rockz4532
Re: MagLite upgraded to a Rebel!!
i wonder if the regulation is different.
Bad news indeed. The logical choice would have been to go to a TFFC K2. Very disappointing.
On the other hand, maybe they changed the circuit? Someone will have to get one of these new MagLED's and check current at the LED etc.,
Yes and no. The K2 creates lots of heat when running at full power, and as we all know the Mag design is horrible at dissipating heat away and then throttles back making all that possible horsepower useless. It would be like putting 155/80/12 Geo Metro tires on a Ferrari.
I think the 0100 would be a better option, or a Seoul p4. Too bad they botched the design from the start.![]()
I thought that the K2 was supposed to be more robust at handling heat?Considering the design limitations with no heatsinking the LED isn't going to be driven hard for very long anyway.With all the problems TerraLUX had with Seouls from the start I can't see how they would be a better option in a light without heatsinking.The Rebel 60 sounds like a cost effective solution for Mag but I also would rather have the TFFC K2.
My Home Depot has 2D Mag-leds with Rebels, and since a package was already open, I took it out and checked it out today. (sorry no camera)
First thing - The old packaging had a picture that showed the LED module and a PR incan module with arrows indicating one could swap them: on the newer Rebel models, this pictures is gone.....
.....because as far as I can tell the Rebel LED module is not removeable :thumbsdow. There is no screw-on collar like the old ones had. In fact, I even went at it with a pair of pliers to see if I could pull it out, but had no luck.
The light is still focusable however.
I'm willing to bet this new module and its inability to be removed and swapped are a cost savings from Mag instead of any real upgrade.
That's too badBut do you think it's possible that they improved the heat sinking?
Rebel 60s do not qualify as relatively new parts.Maglite using relatively new parts?
To ring out the maximum lumens from a K2 you have to push them at 1.5 amps, and these things generate some serious heat. I have one in a Mag and must say I love the tint. It does focus to a needle point but does not have any spill, the Seoul give a good combination of both and a decent tint if you get the right bin.
The K2 TFFC's should be able to handle the heat better, but at the same time they put off alot of heat which will cause the module to throttle back the current which equals a dimmer light. Don't get me wrong, I love the Philips/Lumileds LEDs but they have been surpassed IMO by Cree and Seoul. I wish they would get back in the game.
I also wonder if a Rebel would hold up isolated in a Magled module.
Rebel 60s do not quality as relatively new parts.
Mag keeps disappointing. Wouldn't have expected anything else.
Next step: Cree P4s when everybody else will be using R5s (or whatever we'll have by then).
I did enquire to Gene M. about the warm CREEs but they apparently don't work well with the stock Mag reflector.
